Hei.
Det kommer nok snart :
I have just finished the new proto type B/J wide five front kit that will bolt right on to the following cars:
Bug B/J front stock early drum spindle 1966-1968 ½
Bug B/J front stock late drum spindle 1968 ½ -1977
Ghia B/J front drum spindle 1966
Ghia B/J front disc spindle 1967-1968 ½
Ghia B/J front disc spindle 1968 ½ -1974
T-3 disc spindle 1966-1971
(Still working on making these fit on Super Beetles!)
Most aftermarket L/P lowered disc brake spindles
Most aftermarket B/J lowered disc brake spindlesThe kit will be about 15 lbs lighter then my first design!
With stock spindle, there is zero off-set!
On lowered disc spindles, the only off-set is that of the spindle!
Oh, I have zero off-set B/J lowered spindles coming soon also!!Merk den siste linjen
![Glad](http://www.vwnorge.no/Smileys/default/smiley.gif)
Mvh Lars VW Veterandeler
