desember 27, 2024, 08:52:42 am *
Sider: 1 [2] 3 4
Skrevet av Emne: Min 54/60mod Ragtop...  (Lest 43730 ganger)
« Svar #30 på: januar 27, 2011, 11:52:38 am »
Da jeg ble bitt av kubikk syken, ble det til at jeg byttet ut min 1776ccm.
Her er ny motoren  Gliser.
2332ccm
Motoren er bygget av et firma som heter So Cal Performance i Usa.
Motor spec fra So Cal Performance.
New as41 case:stroker clearance full flowed, sand sealed, 8 chromoly stud kit,
aspiratet 9.1:1 compression ratio.
94 Crank: forged/nitrated balanced and counter weighed,
8 dowel, chevy journals with allen plugs,
CB straigt cuts w/german bearing set.
Rods: forged H beams 5.4 length chevy journal w/arp 2000 bolts.
Cam: slr custum grind cam series.
Lifters: Heavy duty hardened and coated lifters clearance for perfect fit.
Piston kit: Mahle cylinders and barrels mm stroker set, with truarc rist pin retainers.
Heads: New casting custom 42x37,5 port and polish HD dual higt rev springs, HD keepers, chromoly retainers and match ported mainifolds.
Rockers: forged 1.4 ratio rockers with HD solid rockers shafts and CB HD lash caps.
Push rod tubes and push rods: stainless steel push rod tubes CB HD chromoly push rods. 058 3/8 manton
Flywheel: Chromely flywheel 12lb 8 dowel, with stage 1 kennedy w/HD disk.
Pump: 30mm shadek pump tapped plugged for full flow
Pulley: Black CB lazer cut pulley, sand seal clearanced, with chrome pulley bolt ekstra long.
Dual 44mm idf weber CB complete kit, bolt om valve covers, engine seal kit,
11/2 Q oil sump.all new black, new oil cooler w/base.
Ignition: Complete electronic ignition system with new 009 distributor.
Eksosen er et rustfritt Csp Phyton anlegg
* P1000970[1].jpg (97.58 KB. 507x480 - vist 781 ganger.)
Etter litt fundering å prøving er jeg på vei mot en ny look......
* P1000973[1].jpg (113.61 KB. 640x480 - vist 764 ganger.)
Mvh Svein.
« Siste redigering: mars 12, 2022, 20:58:10 pm av Svein. » Loggført
« Svar #31 på: januar 27, 2011, 11:54:57 am »
Hvor ble det av bildet?
« Svar #32 på: januar 27, 2011, 12:10:42 pm »
Ble litt feil dette. Kommer bilder om litt.......................
« Svar #33 på: januar 27, 2011, 14:27:06 pm »
Da er det bilder Eivind Blunker
« Svar #34 på: januar 27, 2011, 14:49:32 pm »
Herlig!
« Svar #35 på: januar 28, 2011, 10:39:16 am »
Ser bra ut Svein, gratulerer!! Har du fått noen spec på kammen?
1302super
Bosted: ski
« Svar #36 på: januar 28, 2011, 12:12:37 pm »
hei:) får jeg spørre hvor mye det kostet deg å få denne bygget og sendt?
Pål.H
Bosted: Nord for Oslo
(o\ /o) og (o= =o) og [o*o]
« Svar #37 på: januar 28, 2011, 12:35:20 pm »
Deilig å se at VW er tilbake med hekkmotor....
Dette kler en Audi.
Jeg er klar hvis du trenger hjelp med å få dyret inn...
« Svar #38 på: januar 28, 2011, 16:40:11 pm »
Nei ikke ennå. Venter spent selv.
Pål:
Takker. Lurte egentlig på hvorfor det gikk så mye fortere hjem Øyerulling Men der slo det meg Osteaktig
Ingen hast, da girkasse skal bygges å byttes Blunker
Mvh Svein.
« Siste redigering: januar 28, 2011, 19:50:26 pm av Svein. » Loggført
« Svar #39 på: februar 02, 2011, 14:34:22 pm »
Da er motor snart klar for benken Kult
* 3 (Medium).jpg (77.78 KB, 800x570 - vist 669 ganger.)
* 5 (Medium).jpg (92.53 KB, 800x667 - vist 657 ganger.)
* 684 (Medium).jpg (77.26 KB, 800x590 - vist 618 ganger.)
* 45643 (Medium).jpg (36.11 KB, 399x600 - vist 572 ganger.)
« Svar #40 på: april 07, 2011, 01:53:27 am »
Litt lyd......
Det er heldighvis ikke farlig røyk fra motoren, Bare et LITT støvete gulv. + muligens litt feit blanding.
« Siste redigering: april 07, 2011, 07:25:53 am av Svein. » Loggført
Hans Christian
1967 T2
« Svar #41 på: april 07, 2011, 07:00:55 am »
Dette blir bra ! Glad
sandvik996tt
« Svar #42 på: april 07, 2011, 08:19:41 am »
Grattis med ny motor .
Noen bør sponse Andersen med en ny genser  Gliser
Andersen Racing
Bosted: Spydeberg
« Svar #43 på: april 07, 2011, 14:04:03 pm »
Hei Svein
det er kun olje på gulvet ikke støv  Gliser
er det noen her som lager gensere str xxl til en billing penge?? Sjokkert
Andersen Racing
sandvik996tt
« Svar #44 på: april 07, 2011, 14:11:06 pm »
Hei Svein
Andersen Racing
 Gliser Gliser Gliser Gliser
« Svar #45 på: april 07, 2011, 14:18:44 pm »
Hei Svein
Andersen Racing
Heisan Kåre.
Trodde du ble sponsa på jobben jeg Øyerulling Ser jo slik ut Blunker
Mvh Svein.
« Svar #46 på: april 07, 2011, 14:21:37 pm »
Få justert gassera slik at den ikke går så fett så unngår du å vaske oljefilmen av sylinderveggene. Deretter gjelder det å få kjørt inn ringene, forsåvidt en morsom jobb.
Grattis! Liker lyden.
« Svar #47 på: april 07, 2011, 14:48:16 pm »
Hei Svein
Andersen Racing
Hadde du brukt L så skulle du fått en Putte genser av meg :-)
1959 Ragtop
Bosted: Revetal
Ny motor :-)
« Svar #48 på: april 07, 2011, 15:05:22 pm »
Gratulerer med ny motor Svein.
Du får passe på så ikke lappen ryker !
VWhilsen Alf
Mitt tlf nr er : 94 54 19 72
« Svar #49 på: april 07, 2011, 15:13:33 pm »
Takk igjen Alf.
Kjører da bestandig pent jeg Øyerulling
Mvh Svein
Ps: Når man er inne på denne mannen som bestandig går i rødt Osteaktig Osteaktig
« Siste redigering: april 13, 2011, 08:17:38 am av Svein. » Loggført
« Svar #50 på: juni 10, 2011, 12:30:34 pm »
Går for tiden veldig sakte her, da jeg har vært litt inn og ut av sykehus i vinter/vår.
Men litt er da blitt gjort med hjelp fra gode venner. Må derfor rette en takk til Ole, Børge og Tore for all hjelp. Må heller ikke glemme Spydeberg`s store sønn Kåre Andersen.
Takk gutter, uten dere hadde dette tatt meg lang tid å få i orden.
Litt av det som er gjort:
Ut med girkasse.
* DSC_0036.jpg (79.51 KB. 640x360 - vist 550 ganger.)
Inn med ny kasse fra JEE og cup stag.
* DSC_0093-1.jpg (60.77 KB. 489x423 - vist 625 ganger.)
Kanskje det blir oppstart og prøve tur til uka hvis formen holder seg.
Mvh Svein.
* P1010148.jpg (131.42 KB, 604x480 - vist 570 ganger.)
« Siste redigering: mars 06, 2012, 21:40:07 pm av Svein. » Loggført
« Svar #51 på: juni 10, 2011, 12:45:21 pm »
Ser bra ut, men di nedre festene på cup staget er montert feil.
Snu dem og monter dem ca 11 og 1.
« Svar #52 på: juni 10, 2011, 12:56:12 pm »
Det blir litt vanskelig, da stagene blir for lange hvis jeg vrir de opp til 11 og 1 Tvilende
Det var kun slik jeg fikk det til å passe.
Får kanskje se på de en gang til, hmmm....
Mvh Svein
« Siste redigering: september 08, 2011, 10:50:03 am av Svein. » Loggført
« Svar #53 på: juni 10, 2011, 13:28:56 pm »
Ok, for sånn det står nå gjør det nesten ikke noe arbeid, festene kommer bare til å vri seg att å frem.
« Svar #54 på: juli 27, 2011, 17:36:13 pm »
Da har vi hatt en tur ned til VW veterandeler, og fått litt hjelp til montering av popout`s og ny front rute.
Jobben var gjor på 3,5 effektive timer Glad .Gikk greit med hjelp av proffe karer.
Tusen takk for hjelpen gutter.
* DSC_0009.jpg (80 KB. 640x425 - vist 548 ganger.)
Der var de inne Glad
* DSC_0011.jpg (75.36 KB. 640x425 - vist 549 ganger.)
* DSC_0021.jpg (81.24 KB. 640x425 - vist 547 ganger.)
Da var det front rute. Fikk tak i en grønn tonet m/sort stripe på Finn.no Gliser
* DSC_0027.jpg (73.62 KB. 425x640 - vist 468 ganger.)
* DSC_0037.jpg (87.95 KB. 640x425 - vist 539 ganger.)
Ferdig.
* DSC_0041.jpg (84.8 KB. 640x425 - vist 507 ganger.)
« Siste redigering: juli 27, 2011, 19:05:38 pm av Svein. » Loggført
« Svar #55 på: juli 27, 2011, 19:13:19 pm »
Is pause på vei hjem. Med på turen var også Ole bomo.
Da er bilen klar for Scc.
Så får vi ta oppgraderingene i løpet av vinteren, og prøve og få godkjent bilen til sommeren 2012
* DSC_0043.jpg (109.52 KB. 640x388 - vist 561 ganger.)
* DSC_0046.jpg (99.11 KB. 640x395 - vist 530 ganger.)
« Siste redigering: mars 06, 2012, 21:42:50 pm av Svein. » Loggført
« Svar #56 på: mai 10, 2015, 21:57:17 pm »
Litt skjer det her og.
2012.
* image.jpg (15.75 KB. 294x220 - vist 471 ganger.)
2013.
* image.jpg (20.99 KB. 327x198 - vist 484 ganger.)
2014.
* image.jpg (77.47 KB. 800x534 - vist 465 ganger.)
2015.
Stripestil.
* image.jpg (87.11 KB. 600x600 - vist 472 ganger.)
« Siste redigering: mai 11, 2015, 23:14:53 pm av Svein. » Loggført
« Svar #57 på: mai 10, 2015, 22:09:40 pm »
2015
Tur/gate stil.
* image.jpg (160.23 KB. 800x600 - vist 514 ganger.)
* image.jpg (141.83 KB. 800x600 - vist 516 ganger.)
* image.jpg (63.12 KB. 800x464 - vist 476 ganger.)
* image.jpg (63.89 KB. 800x483 - vist 486 ganger.)
Da kan sommeren komme...
« Siste redigering: mai 11, 2015, 23:12:32 pm av Svein. » Loggført
RIN94
Bosted: Rogaland- Nærbø
« Svar #58 på: mai 11, 2015, 20:52:35 pm »
Flott bil Svein!  Glad
Må si jeg personlig synes "2015 stripestilen" kledde den best  Blunker
1300 - 68mod
« Svar #59 på: mai 11, 2015, 21:04:29 pm »
Er det plastidip? Jeg liker best gatestilen og det eneste som gjenstår er å erstatte T-barsene bak med fanger. Fin bil med attitude! Gleder meg til å se den i aksjon i Brumunddal!
Sider: 1 [2] 3 4
