juni 26, 2024, 00:36:13 am
Nyheter
CB 1.4:1 vipper + Engle Fk10 kr 2100
Emne: CB 1.4:1 vipper + Engle Fk10 kr 2100 (Lest 871 ganger)
Frid
Bosted: Ringsaker
april 14, 2010, 19:15:23 pm »
Nye vipper fra CB
Engle FK10
Fk-10 Offers 310 Degrees Duration And .385" Lift At The Cam. With 1.4:1 You Get A Whopping .539" Lift At The Valve.
Forged from 4340 Chromoly steel and CNC machined to an exact 1.4:1 ratio! The rockers feature hardened tips, bronze bushings, and H-11 Tool Steel adjusting screws. The absolute strongest adjusting screws available! The rockers feature 100% pressure oiling to eliminate the problems associated with splash oiled rockers. The hardened shafts are a gigantic .984" in diameter, 38% larger than stock rocker shafts! The rocker shafts are cradled in forged Chromoly rocker blocks. Forged 1.4:1 rockers are shipped in complete sets which includes 8 rockers, 2 shafts, 4 rocker blocks, 4 Heavy Duty Chromoly Rocker Studs, adjusting shims kit, 2 end caps, and 2 bolts, 8 valve caps, 8 adjusting screws and lock nuts.
Pris 2100 for begge
Mvh tor 45217555
(99.7 KB, 1037x778 - vist 128 ganger.)
Siste redigering: april 25, 2010, 18:00:19 pm av Frid
1967 notch
1968 Variant 1600L
1966 karman ghia
1968 Variant 1600
Frid
Bosted: Ringsaker
Sv: CB 1.4:1 vipper selges
april 20, 2010, 21:09:05 pm »
1967 notch
1968 Variant 1600L
1966 karman ghia
1968 Variant 1600
Frid
Bosted: Ringsaker
april 23, 2010, 15:06:18 pm »
Ingen som trenger mer løft på ventila?
1967 notch
1968 Variant 1600L
1966 karman ghia
1968 Variant 1600
Frid
Bosted: Ringsaker
Sv: CB 1.4:1 vipper + Engle Fk10 kr 2100
april 25, 2010, 18:00:45 pm »
2100 for kam og vipper
1967 notch
1968 Variant 1600L
1966 karman ghia
1968 Variant 1600
