sammyboy
![*](http://www.vwnorge.no/Themes/default/images/star.gif) ![*](http://www.vwnorge.no/Themes/default/images/star.gif)
Bosted: trondheim
« på: oktober 04, 2013, 09:54:14 am » |
Hei
Does anyone know if its legal to use a A shaped towing frame in Norway? If so where can I buy one from? Thanks
Sam
« Svar #1 på: oktober 04, 2013, 11:09:29 am » |
I would contact the "DMV" (Biltilsynet) and ask them.
Telefon: 02030
vegvesen.no
JarleA
« Svar #2 på: oktober 04, 2013, 12:17:49 pm » |
Har sett sånne på både engelske og amerikanske forum. Lurer på hvordan sånne er å kjøre med. Hvordan blir det med sving og sånt?
![*](http://www.vwnorge.no/Themes/default/images/stargmod.gif) ![*](http://www.vwnorge.no/Themes/default/images/stargmod.gif) ![*](http://www.vwnorge.no/Themes/default/images/stargmod.gif) ![*](http://www.vwnorge.no/Themes/default/images/stargmod.gif) ![*](http://www.vwnorge.no/Themes/default/images/stargmod.gif)
« Svar #3 på: oktober 04, 2013, 12:34:37 pm » |
I believe it's not legal.
'67: 10.626@213,65 SCC2016 10.407@215,57 SCC2017 10.221@216,87 SCC2018 Norges raskeste luftkjølte gatebil? '59: Snart ![](http://vwnorge.no/dkllogo.png)
sammyboy
Bosted: trondheim
« Svar #4 på: oktober 04, 2013, 13:30:13 pm » |
Thanks for the replies. All I could find on the net was that its legal in sweden. I've seen campers towing small cars with them. Shame if not legal.
« Svar #5 på: oktober 04, 2013, 23:12:34 pm » |
A tow bar works in Norway in the same great way as it works in any other country... I have used it a lot.
But - legally you are only allowed to tow a trailer of 350kg if it has no active brakes.
So - yes it works, but it is not legal.
« Svar #6 på: oktober 04, 2013, 23:38:23 pm » |
Are you allowed to tow a trailer at all that´s not registered as one?
« Svar #7 på: oktober 04, 2013, 23:58:46 pm » |
can it be called a trailer at all? will be the same as for these: http://www.the.no/images/bannernyhetsbrev_uke14_2013.jpgor is it a trailer as long as there is no-one inside the towed car? but have not seen these for sale in norway, guess you need to import one, or make one
-tlf. 97419035 T-Mek AS
« Svar #8 på: oktober 05, 2013, 00:04:39 am » |
I think you will run into problems related to the weight of a towed car and the fact that it will have no brakes. Normally a trailer intended for a car require brakes, while smaller trailers (I think it is up to 350 kg) does not require brakes.
A.Hole
« Svar #10 på: oktober 05, 2013, 12:32:11 pm » |
Så vidt jeg kan se er det egne regler for tauing. En bil blir m.a.o ikke en tilhenger selv om det er stag i mellom.
Men kravet til bremser er der. Dvs du kan kun taue med stag i Norge dersom du har
1: forsvarlige bremser på bilen som blir tauet, 2: en tauepartner som aktiverer bremsene i bilen som blir tauet.
Men som vanlig, sikkert lover med rom for tolkninger....
« Svar #11 på: oktober 05, 2013, 13:32:11 pm » |
Bilen som taues skal også ha skilt, vanlige skilter eller prøveskilter. Dette er pga personskadeforsikring.
